64 Alternator "clocking" - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2413
    I just had my 64 Flight judged at a chapter meet, and the judges said my alternator may be "clocked" wrong. See picture below. Comments please, do you just take out the bolts and turn CW/CCW?
  • Dan H.
    • July 31, 1977
    • 1369
    Re: 64 Alternator "clocking"
    Looks good, my 64 with AC was like yours, rare car !
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Leif A.
      • August 31, 1997
      • 3642
      The orientation looks correct to me. However, the hot lead (red) with the boot needs to be clocked whereas the lead comes out of the boot at 6 o'clock. See attached.
      Leif
        Caution! If you attempt to re-clock the alternator, once you remove the screws holding the rear section to the front, the rear is free to move back and pop OFF the drive shaft... You need to take care to apply forward pressure on the rear case to keep it forward enough that this doesn't happen.
        If it does come fully apart, now you're into using your copy of the maintenance manual to see how to spread the fingers of the contact brushes. Specifically you'll want to use those tiny access holes in the rear case to insert brush holding tools (something like a straightened paper clip usually works) so you can re-install the rear case onto the main shaft.
        I once saw a fellow member who attempted to re-clock his alternator at a Regional Meet without knowing what he was doing. He an unhappy camper when the rear case 'popped' back and off the main shaft!!!
        • Leif A.
          • August 31, 1997
          • 3642
          And, push the white nylon "keeper" that's part of the harness back into it's hole in the alternator case.
          Leif
          • John F.
            • March 23, 2008
            • 2413
            Thank you Leif!
            • John F.
              • March 23, 2008
              • 2413
              Thank you Jack. I am just going to re-orient the red wire.
              • Leif A.
                • August 31, 1997
                • 3642
                Be sure to disconnect the battery when doing this. You don't want to ground the wrench when loosening/tightening the red wire with the battery connected.
                Leif
