Re: 55 V8 Differential code - What's yours?
Troy, I think you might be misinterpreting the data I sent. As previously stated, GM changed the rear axle designations in 1955 (1st series) & (2nd series). Starting with the 2nd series, ONLY the 1st letter designates the plant. (Important), the 2nd letter indicates the series car, type rear end and the gear ratio to be installed. Once assigned, the second letter will continue in subsequent years as long as the series and type axle is being assembled. "AE" is a Corvette powerglide 3.55 ratio built at G & A followed by the stamped assembly month and day. No need to stamp the year since that is cast into the carrier along with the casting Number.
The standard 3 spd. Corvette required a 3.70 gear ratio and would be stamped "AH". The optional Corvette gear ratio 3.27 was stamped "AD". The 56-57 JM p. 213 & 214 explains fairly well but does have some errors as well.
The data sent was from Chevrolet Motor Division, GM Corp. "Special Information Catalog" dated 10-1-61.
