1963 Core Support? - NCRS Discussion Boards
1963 Core Support?
  • Bruce B.
    • May 31, 1996
    • 2930
    1963 Core Support?
    Is this core support from a carbureted or FI 63 coupe?
    All info is appreciated.
    Bruce B
  • Jim L.
    • September 30, 1979
    • 1806
    Re: 1963 Core Support?
    I don't see a picture, Bruce.
    • Bruce B.
      • May 31, 1996
      • 2930
      Jim,
      Sorry about the lack of picture.
      But the core support has a large oval hole in the lower part of the drivers side of the core support.
      Actually the engine is stamped RF indicating FI.
      Bruce B
      • Joe R.
        • July 31, 1976
        • 4547
        Bruce,
        The hole for the FI Air Cleaner is in the left upper on a 63-65 Radiator Core Support.
        63's are unique and 64-65 core supports are the same.
        JR
        • Chuck G.
          • May 31, 1982
          • 2029
          Here's a photo of a 63 only FI core support. Note the position of the opening for the FI "S" tube.
          Note the 2 bulges in the lower front, near where the horns would mount.
          64/65 do not have the bulges.
          • William C.
            • May 31, 1975
            • 6037
            No picture, but the FI version has a hole where the FA aircleaner is attached. No hole if for carbureted car. Fairly god size hole on Drivers side.
            Bill Clupper #618
            • John D.
              • November 30, 1979
              • 5507
              Nice Pic Dr. Chuck. What confused the 63 to 65 radiator supports in the old days and maybe a little today was Chevy Parts listing the part 63-65. JD
              • Frank D.
                • December 26, 2007
                • 2703
                I went to great pains to get an original 63 radiator core support for my 63 when having the nose repaired. The Coffman repros are OK but they didn't have the small oval stamped hole for the Powerglide coolant lines as the late 63s had.... (just under where the voltage regulator mounts)...
                Its all about the details!
                • Loren L.
                  • April 30, 1976
                  • 4104
                  To point to a difference in "Then" and "Now", I can remember a Bloomington in the late '80s where in a full class of 10 '63s, there was One correct radiator support.
                  • Bob R.
                    • June 30, 2002
                    • 1595
                    I have noticed some original 63's with and without that hole for the automatic transmission cooling lines I don't think all 63's had that hole. My May car does have it though.
                    • Frank D.
                      • December 26, 2007
                      • 2703
                      Correct. It was a mid-production year change in 63. I have the document somewhere, can't remember if its a TSB or a note on the AIM page...
                      • Marco H.
                        • February 28, 2002
                        • 218
                        Coffman will make you a 63 core support with the cooler line hole. My March built 63 has the hole and Coffman made me a new support to my specs. (Taking about details, they sent me the part uncoated per my request, so I can dip paint it like original.)
                        • Frank D.
                          • December 26, 2007
                          • 2703
                          That's good to know.....
                          I had a chance to get an original one off a one-owner 63 convertible so I went for it.....along with the nose support rods and several other front end parts..
                          • Jim L.
                            • 1806
                            You are correct; that hole was added after PowerGlide cars got transmission oil coolers.
                            My October '62 built '63 (with PG) does NOT have the hole. My (former) January '63 built '63 (with 4 speed) did have it.
