1967 Windshield - Original or a RePoP - NCRS Discussion Boards
  • Gary J.
    • April 3, 2008
    • 152
    Good morning to all:
    the winsheild in my 1967 Coupe was judged to be a RePoP, it was my opinion it was an original. Photo of date marking from outside and photo of shading from inside. Any opinions or assistance in determination of how to tell the difference, thanks in advance. Gary
    New England Chapter NCRS
  • Chuck M.
    • February 1, 2002
    • 335
    Re: 1967 Winshield - Original or a RePoP
    Gary,
    Its a little difficult to tell anything from your photos. You will want to look at a couple of areas of your windshield.
    1) The upper tint on original windshields is narrower in the middle of of the glass and gradually gets wider as it gets to the outer edges. Reproduction can have equal tint all the way across with little or no taper.
    2) The original tint very gradually transitions from tint to clear as you move down the glass. Reproduction glass typically has a very sharp line where the tint ends as you move down the glass.
    3) The AS1 logo should not be felt on either side of the glass as it's actually inside the glass.
    Im certainly not an expert so I am sure there are additional telltale signs but this should get you started.
    • Steve B.
      • March 1, 2002
      • 1190
      Originally posted by Chuck McGettrick (37465)
      Gary,
      Also when looking at the AS1 marking from outside, it will be reversed as if you were looking into a mirror.
      • Donald L.
        • November 1, 1981
        • 140
        The Color of the shading is definitely not original
        • Jim D.
          • 2883
          Based on what? I have 2 65's with original windshields that have the same blue colored shaded band. I've been working with PPG for well over a year trying to get them to make a correct windshield as NOBODY makes a correct one at this time. I meet with the division head every year at SEMA and they're working on it but it is low priority as they are an OEM supplier and that takes precedence.
          • Steve B.
            • March 1, 2002
            • 1190
            Jim, that would be great news if it happens.
            • Gary B.
              • February 1, 1997
              • 7018
              The color in the photo might not be an accurate representation of reality. The camera can affect what the color looks like as can one's computer monitor.
              Gary
              • Jim D.
                • 2883
                I hope it will be "when" not "if" it happens. I've supplied them with multiple pics. and measurements. One of the issues was the gradient in the laminate. They had to go to a different supplier for that material and then it had to be tested. That all went well until more important issues sidelined this project. In March, I was told that they are close to completion but won't be able to return to this project until sometime in June. Let's keep our fingers crossed.
                • Rick A.
                  • July 31, 2002
                  • 2147
                  Re: 1967 Windshield - Original or a RePoP
                  Gary - curious as to what the judges had to say wrt windshield being a repop - what was their rationale using CDCIF - would you please share that information from your scoring sheet
                  Rick Aleshire
                  2016 Ebony C7R Z06 "ROSA"
                  • Gary J.
                    • April 3, 2008
                    • 152
                    • Don H.
                      Moderator
                      • June 16, 2009
                      • 2254
                      Your LOF logo reads from the inside. Your date is UA, not AU. UA is July 1966.
                      • David H.
                        • June 30, 2001
                        • 1521
                        Gary,
                        Does windshield have any “DOT” markings anywhere - indicating a replacement with creation of a “restored” LOF bug?
                        Dave
                        • Gene M.
                          • April 1, 1985
                          • 4232
                          I would use an original windshield given the choice unless it has a bullet hole in it. Clear glass windshield installed correctly, and dated correct is difficult to determine from original. Tinted glass not so much....... Reproduction side window glass is easy to determine non originality clear or shaded.
                          • Gary J.
                            • April 3, 2008
                            • 152
                              • 6940
                              Gary, I think at the meet the lighting was not to good indoors, maybe another pic. of the windshield outdoors from the front will give the guys another view?
