Guys, I need help. When I put my top ignition shielding on (very carefully), the engine tries to start but doesn't turn over. When I remove it (which is how I have driven it so far) it starts right up. I have tried to put it on on two separate occasions with the same outcome both times. The insulator is there and all in tact and the coil is aligned correctly (parallel to the firewall).
One thing I think may be a problem are replacement plug wires which to me appear to be too long and keep the shielding from setting down. I may be able to feed them down a little, but probably not enough. I used a longer screw through the top hole of the shielding in order for it to reach the bracket hole and still be able to get the wing nuts to catch the slots on each side while being sure not to force anything. Didn't work.
It drives great without it and radio works fine, but it has this butt ugly blue distributor cap that I would like to cover up and would like to show it complete. Will change someday, but I have never had this happen with any of the C1's I have had. Thoughts?
