1963 cluster bulbs - NCRS Discussion Boards
1963 cluster bulbs
  • Donald O.
    • May 31, 1990
    • 1585
    Re: 1963 cluster bulbs
    Originally posted by Bill Bonnichsen (32446)
    Frank...You say you didn't change the Lights/Park/High Beam/Turn Signal. Can the LED's be put in those positions or is there a reason they can't. I have been thinking of changing all my instrument panel bulbs but it's not high on my priority list and I was waiting until they got to a point that they are dimmable which I guess they are now. I was wondering on the turn signal bulbs if the flasher would be a problem. Thanks in advance for any input.
    • Frank D.
      • December 27, 2007
      • 2703
      Originally posted by Donald Olson (17357)
      if you are only changing the dash indicators then you don’t have to change the flashers. However, if you’re changing the the front and rear brake and running lights then yes you will need to change to an electronic flasher
      Don
      That is correct....and the electronic flashers are polarity sensitive - so look for one that works on the GM cars or get a polarity reversing adapter...
