cleaning '67 aluminum wheels - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1363
    What to use to clean the bright parts-rim and fins, of the '67 aluminum wheels and stay with factory appearance? Are aluminum polishes too strong or make them too shiny? Not a lot about this in archives,
    .Thanks
  • Gene M.
    • April 1, 1985
    • 4232
    • Ara G.
      • January 31, 2008
      • 1108
      Re: cleaning '67 aluminum wheels
      .Thanks
      I use OOOO fine steel wool on the chrome facia on the starbursts and they come wonderful. I have used the same stuff on the wheel lips as well and it works well.
      • William F.
        • June 9, 2009
        • 1363
        Are Corvette aluminum wheels bare aluminum on the bright areas or do they have a coating? Some wheel cleaners say "not for uncoated wheels."
        • Mark S.
          • July 31, 1983
          • 660
          Just a side note: most of the good mag and aluminum polishes like Mothers, 3M etc. are not recommended for coated wheels
          • William F.
            • June 9, 2009
            • 1363
            But I'm asking:
            1. Are C2 aluminum wheels bare aluminum without coating or anodizing?
            2. Can you use a mag wheel or aluminum "polish' on them without ruining factory appearance- by making too shiny?
            • Phillip M.
              • September 30, 2006
              • 100
              But I'm asking:
              William,
              Using an ohm meter, check for conductivity of the wheel surface. If anodized or clear coated you will not get a reading.
              Phil M.
                • 15672
                There was no coating of any kind on original KOs and early Western repros... don't know about current repros, but I expect they are bare. Cleaners designed for bare aluminum are usually phosphoric acid based and leave a rather dull finish, but you can use metal polish to brighten up the outer machined bead flange.
                The wheels came out of the molds bright, but a surface oxide film that forms rapidly will dull them. By the time new Corvettes with KOs reached the dealers, the surface oxide film had probably fully formed.
