1965 Ignition Switch - NCRS Discussion Boards
  • John L.
    • February 20, 2009
    • 186
    Sirs:
    What are my choices if I needed a new ignition switch??
    Could I use, or modify a '66/67?? Would I need a new lock cylinder?
  • Gary B.
    • February 1, 1997
    • 7080
    Re: 1965 Ignition Switch
    John,
    The ignition switch for '65 was one year only. As was the switch for '66 and '67. So each year was unique. The GM # for the '65 switch is 1116660. You can find them as NOS examples. One will probably cost you $150 +/-.
    Gary
    • Leif A.
      • August 31, 1997
      • 3657
      John,
      Contact David Sokolowski out in California. He advertises in the Drive Line.
      Leif
      • Peter L.
        • May 31, 1983
        • 1930
        John - While the '65 ignition switch, p/n 1116660, is for 1965; it's important to note that the ignition lock cylinder p/n 3869215 is
        for the 1965 & so the 1965 p/n 3869215 ignition lock cylinder will not work in either the 1966 p/n 1111673 ignition switch or the
        1967 p/n 1116686 ignition switch & as you might guess the 1966 ignition lock cylinder, p/n 7031272 & the 1967 ignition lock cylinder,
        p/n7033216 will not work in the 1965 ignition switch. Also, the 1965 & 1966 ignition lock cylinders use the GM/Briggs & Stratton
        B10 keys, wile the 1967 ignition lock cylinder uses the "A" letter code keys & by design the 1965-1966 B10 key will not go into the 1967
        "A" letter code key ignition lock cylinder & visa-versa. Who says "working on old cars isn't FUN. Pete
        • Gene M.
          • April 1, 1985
          • 4233
          Little known secret, the ‘65 Cadallic uses the same ignition switch as well as door locks as ‘65 Corvette.
          • Joe R.
            • July 31, 1976
            • 4552
            John,
            I have a used 660. If you want more information you can contact me via a personal message.
            Joe
            • John L.
              • February 20, 2009
              • 186
              Joe
              Thank you - I appreciate the response.
