Courtesy light switch - NCRS Discussion Boards
  • Rod R.
    • August 31, 1984
    • 110
    The courtesy lights on my 64 roadster will not shutoff. I found the driver side courtesy light switch needs to be adjusted out more (toward the door hinge). How is that done? I can see the switch nut and a 7/16 socket will fit it but there must be another nut on the hidden side. I cannot remember how it works. Any help is appreciated.
  • Mike M.
    • May 31, 1974
    • 8388
    Re: Courtesy light switch
    there is no nut on the back side of the switch. the metal in the door jamb is tapped . remove the switch and place a washer between the switch and the door jamb and hope the thickness of the flat washer is enough to close the switch. mike
    • Rod R.
      • August 31, 1984
      • 110
      Thanks Mike, I'll give it a try. Rod
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        If the Barrel is seized the washer may help.
        It's a self adjusting design. If the barrel is too loose you can try squeezing it a bit to recreate the friction fit.
        • Russ S.
          • April 30, 1982
          • 2162
          The proper way to fix it is to remove the switch and tap the barrel all the way out toward the door. If it is a loose fit then deform the barrel slightly so it becomes a tight fit again. Re install and close the door. It will auto adjust to the correct position.
          • Rod R.
            • August 31, 1984
            • 110
            Richard and Russ, thanks for the excellent diagram and explanation on the adjustment procedure. Now the challenge will be to remove, adjust, and install the switch. I did it years ago but cannot remember the process. I think the dash was out of the car then, which would made access easier. Thanks for your help guys.
            • Rod R.
              • August 31, 1984
              • 110
