1955 engine bolts - NCRS Discussion Boards
1955 engine bolts
  • Ronald R.
    • May 31, 1989
    • 671
    1955 engine bolts
    anyone know where to get misc bolts? correct ones thanks Ronnie
  • Wayne L.
    • September 30, 1981
    • 233
    Re: 1955 engine bolts
    I have been getting original bolts from core engines that I buy on Craigs List, etc. Also junkyards with older cars have cars with engines in them, or if they have pulled engines they will have a bunch or engines just laying around. I do have some bolts left. Are you looking for certain bolts? I have a bunch of head bolts, some original AP bolts for the intake, etc.
    • Jeffrey S.
      • May 31, 1988
      • 1899
      Try Richard Fortier. He advertises in the Driveline.
      Jeff
      • Ronald R.
        • May 31, 1989
        • 671
        exhaust manifold, distributor hold down to start with. thanks RDR
        • Wayne L.
          • 233
          Exhaust manifold bolts are typically not re-usable. I do not have any, sorry. Fortier may have some but they will be expensive!
          • Troy P.
            • February 1, 1989
            • 1284
            Corvette engine bolts are not special. All 55 Chevy's used the same bolts on V-8 engines. So you must shop at the 55-57 Chevy parts dealers for selection and lower prices that you would get from a Corvette supplier. But Paragon does have bolts too at Corvette prices.
            Ecklers has Classic Chevy parts as well as many, many other companies. But my favorite supplier is East Coast Chevy in Doylestown, PA, where my brother and sister live.
            Get the exhaust bolts with the thick steel washers, unless you have the washers. Some sell with and without. Also you can't go wrong with the common WB1C for the distributor clamp.
            • Dan P.
              • December 1, 1990
              • 683
              Call me i have most of them Dan patch
              • Troy P.
                • February 1, 1989
                • 1284
                I have seen plain head bolts on the distributor hold down as well as WB1C. Its an odd sized bolt. Large diameter but quite short. Also the bolt should be painted orange as well as the hold down.
