Front sway bar - NCRS Discussion Boards
Front sway bar
  • Mel S.
    • August 31, 1992
    • 264
    Front sway bar
    Putting new polyurethane bushings in the front sway bar of my 66. The package state to lubricate the bushings before installing but does not specify what to use. Does anyone know what kind of lube to use?
    Mel
  • Jim S.
    • March 13, 2013
    • 360
    Re: Front sway bar
    Mel
    Curious, why did you decide to use polyurethane?
    • Mel S.
      • August 31, 1992
      • 264
      Re: Front sway bar
      Just wanted to.
      Mel
      • Michael M.
        • February 1, 1993
        • 606
        Re: Front sway bar
        Amsoil makes a good heavy duty synthetic grease that is moly fortified.
          • 43284
          Re: Front sway bar
          Mel------
          I don't recommend urethane, at all, especially for sway bar bushings.
          • Alan D.
            • January 1, 2005
            • 2054
            Re: Front sway bar
            Second Joe! Unless you are racing do not use.
            • Mel S.
              • August 31, 1992
              • 264
              Re: Front sway bar
              Why do you not recommend them?
              • Joe R.
                • July 31, 1976
                • 4552
                Re: Front sway bar
                Joe and others don't recommend them because they are of no use for anything however they will last longer then rubber. They also make noise, transfer vibration thru the Corvette and don't make your Corvette drive better and maybe even worse.
                JR
                  • 15706
                  Re: Front sway bar
                  The pillow block bushings or link bushings? My recommendation, based on experience, is to only replace the rubber link bushings with polyurethane. Keep the OE type rubber pillow block bushings.
                  Hard link bushings will mitigate the transition to oversteer at the limit of adhesion or when you lift off the throttle. The problem is that the rubber link bushings compress at high lateral g, which reduces front the roll stiffness. This effectively increases rear roll stiffness distribution, which will alter the balance from mild understeer to oversteer.
                  It's also critical to having proper rear toe-in, with the total SPLIT EQUALLY BETWEEN BOTH SIDES!
                  Clean and smooth the machined bushing wells in the bar and same with the steel retainers. Any "EP" type chassis/wheel bearing grease should do fine. If they start squeaking it's time to clean and regrease.
                  See the nearby thread on the fastener installation sequence.
                  • Mel S.
                    • August 31, 1992
                    • 264
                    Re: Front sway bar
                    thanks for the info
                    Mel
                    • Michael M.
                      • February 1, 1993
                      • 606
                      Re: Front sway bar
                      If you want to update and improve your suspensions performance use the polyurethane bushings. I have been using them for years without them failing or making noise in any way. Consider the replacement a upgrade from rubber. Just make sure you grease them and you good to go.
