Where to go to get 1980 differential & cover? - NCRS Discussion Boards
  • Billy S.
    • April 23, 2015
    • 52
    Hello All,
    I have a 1980 4 speed which needs a new differential and differential cover (batwing). My differential housing is probably useable as a core, my cover is definately not (someone broke a bolt off in it a loooong time ago) my rear spring has been jury rigged into place. Whose the best to go to to get one off the shelf? I don't want to rebuild my unit because I don't want to tie my friends lift up while I'm waiting and the differential in the car has already been replaced once (dated 1981).
    Thanks!
    • 43211
    Re: Where to go to get 1980 differential & cover?
    Originally posted by William Schoenberg (61142)
    Hello All,
    Thanks!
    William------
    I'd suggest Ikerds's Corvette in Bedford, IN. Pat Ikerd passed aways some time ago but the business is still being capably run. You can get a completely rebuild differential unit for about $1,000 + core charge. I don't know if they have the covers, or not. However, even if they do not, I'm sure they could tell you where to get one.
    • David H.
      • June 30, 2001
      • 1522
      ... useable as a core, my cover is definately not (someone broke a bolt off in it a loooong time ago) my rear spring...
      William,
      Had same problem with broken bolt. If someone has NOT tried to drill it out, etc, then a machine shop can remove bolt and replace threads with helicoil. I believe machine shop had some kind of “electro” vaporizing machine - however they did it, not very expensive.
      Dave
        • 43211
        William,
        Had same problem with broken bolt. If someone has NOT tried to drill it out, etc, then a machine shop can remove bolt and replace threads with helicoil. I believe machine shop had some kind of “electro” vaporizing machine - however they did it not very expensive.
        Dave
        Dave------
        It's called an Electrical Discharge Machine (EDM).
        By the way, I believe the reason that these bolts seize is due to dissimilar metal (galvanic) corrosion.
        • Bruce C.
          Infrequent User
          • December 1, 1988
          • 13
          Contemporary corvette salvage,Bristol,Pa.
            • 6940
            William, there's a 80 rear diff on Boston Craig's list, out of Automatic, 30 day warranty. been is dry storage foe 30 years.
