1972 vs 1973 Wiper Blade Holder Size - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    I believe 73 & 72 take a 16" Trico black wiper blade holder. Are they the same for both years? I have a late 72.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 1972 vs 1973 Wiper Blade Holder Size
    They are the same.
    • Jack C.
      • 1090
      Thanks Russ.
      Jack Corso
        • 43246
        Originally posted by Jack Corso (21713)
        Thanks Russ.
        Jack-------
        All 1968 to 1981 Corvettes use 16" wiper blades and these are functionally interchangeable. 1982 also uses a 16" blade but it's not interchangeable with earlier.
        • Jack C.
          • 1090
          Thanks Joe!
          Jack Corso
          • Harmon C.
            • August 31, 1994
            • 3228
            All 16" Trico blade holders are not configered the same if judging is in your future.
            Lyle
              • 43246
              Lyle------
              That's why I used the term "functionally" interchangeability. Also, I didn't mean that all 16" blades are functionally interchangeable, only that all of the 1968-81 Corvette 16" blades are interchangeable. As far as configuration goes, there is a myriad of configurations.
              • Harmon C.
                • August 31, 1994
                • 3228
                [QUOTE=Joe Lucia (12484);828555]Lyle------
                That's why I used the term "functionally" interchangeability. Also, I didn't mean that all 16" blades are functionally interchangeable, only that all of the 1968-81 Corvette 16" blades are interchangeable. As far as configuration goes, there is a myriad of configurations.[/QUOTE
                Joe
                I know what is correct for 68+81 Corvettes.
                Lyle
                • Jack C.
                  • 1090
                  [QUOTE=Lyle Chamberlain (24961);828572]
                  Lyle------
                  Joe
                  I do indeed have judging in mind. I was referring to a clip-type 16" black Trico with TRICO Made in USA on both ends.
                  Jack Corso
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    I du not have a picture but it needs to be wide on top not pointed.You could post or E mail me a picture of what you have.
                    Lyle
