Fuel Gauge 1966 - NCRS Discussion Boards
Fuel Gauge 1966
  • Joe T.
    • February 25, 2018
    • 153
    Fuel Gauge 1966
    The fuel gauge stays at a half tank. Doesn't matter if the tank is full or empty. Car had sat for three years. Any suggestions of what the fault would be. I am thinking the sending unit float is stuck at that position. Haven't done a ohms check or ground yet. Didn't want to remove the dash at this time or pull the sending unit.
    • 43295
    Re: Fuel Gauge 1966
    Joe------
    Most likely, it's as you surmise. You should be able to reach into the tank to feel the float position. However, it might require removing the filler neck. This is quite easy. A new filler-to-tank gasket is probably in order, anyway.
    • Russ S.
      • April 30, 1982
      • 2163
      Re: Fuel Gauge 1966
      Grab the float with a piece of wire and raise it up. Check the gauge for movement. Also check the float itself for damage or saturation.
      • David H.
        • June 30, 2001
        • 1577
        Re: Fuel Gauge 1966
        Joe
        Brake lights work? Does apparent fuel level change when you step on brake pedal?
        If so, check ground.
        Dave
        • Joe T.
          • February 25, 2018
          • 153
          Re: Fuel Gauge 1966
          Brake lights work. Will check the float..
          • Frank D.
            • December 27, 2007
            • 2703
            Re: Fuel Gauge 1966
            The C2 fuel gauge/sender arrangement is kind of unique....it uses a powered sending unit to create a voltage divider circuit...the float 'picks off' the voltage that the gauge reacts to and produces the level indications. To wit, testing these is a bit trickier than a C1/C3 setup. 1/2 way through this MS-Word article are some methods for on-car and off-car testing (which requires a 100 ohm potentiometer)...
            • Joe T.
              • February 25, 2018
              • 153
              Re: Fuel Gauge 1966
              Thank you..
              • Jimmy G.
                • November 1, 1979
                • 977
                Re: Fuel Gauge 1966
                Typically when the sender goes bad it reads half tank so odd are sender is kaput Common problem My tanker reads 1/2 full and I am not going to pull the tank again to fix it again so I speak from some experience
                • Joe R.
                  • July 31, 1976
                  • 4552
                  Re: Fuel Gauge 1966
                  Mr. Gregg,
                  99 times out of 100 you are correct as usual.
                  JR
                  • Michael J.
                    • January 27, 2009
                    • 7180
                    Re: Fuel Gauge 1966
                    Yes, Jimmy has it right. If you will notice, new gas gauges for C2s are at 1/2 in the box, totally disconnected. So the problem is more than likely the sending unit, that's the bad news. The good news is that it is much easier to replace a sending unit than a gauge in a C2 cluster.
                    • Joe T.
                      • February 25, 2018
                      • 153
                      Re: Fuel Gauge 1966
                      I bent a clothes hanger and moved it around the float, from what I could feel. Now the gauge goes to 1/4 with key off and 1/2 with key on.
                      • Michael J.
                        • January 27, 2009
                        • 7180
                        Re: Fuel Gauge 1966
                        I think that just means your gauge is working, if you were to ground the brown wire from the sending unit, it will probably read full. You could check the pink wire to make sure you have 12V there, most likely you do. You can check the black ground wire too to make sure it is grounded. However, it seems to show all the signs of a non-working sending unit.
                        • Joe T.
                          • February 25, 2018
                          • 153
                          Re: Fuel Gauge 1966
                          Thank all of you. I ordered a sending unit today.
                          • Michael J.
                            • January 27, 2009
                            • 7180
                            Re: Fuel Gauge 1966
                            Good luck! I wish I could order one for mine that is not working, but alas they do not reproduce them ('64 big tank). So I will have to pull the cover, a nasty job, and pull the old one to be rebuilt by probably the only guy in the country that does that. It will be more expense than you are looking at, but your undertaking here has inspired me to do it soon.
                            • Jimmy G.
                              • November 1, 1979
                              • 977
                              Re: Fuel Gauge 1966
                              Michael
                              I have had my big tank out three times and the unit still does not work Found a NOS one in Carlisle for $ 3000 I passed
