64 Tach needle replacement help - NCRS Discussion Boards
    • 6958
    Looking to see if anyone has replaced the tach. needle in a 64, is it a friction fit or rotate needle? thanks for your advice, Ed
  • Ken A.
    • July 31, 1986
    • 929
    Re: 64 Tach needle replacement help
    If I had to guess, I would say it's a friction fit & you twist it to the left while pulling outward.
    • Harry S.
      • July 31, 2002
      • 5345
      Ed, just did my 63. The same part number is used in 63/64 for the needle/pointer. It's a simple push-on or friction as you say.
        • 6958
        Thanks guys, I installed all set.
