Need GM Part Number - NCRS Discussion Boards
Need GM Part Number
  • Ed D.
    • December 1, 1990
    • 329
    Need GM Part Number
    Original GM Part Number for 1972 POA Air Condition Valve.
    Ed
    Ed DiNapoli
    CNJ Chapter Past Chairman/Co Founder
    1972 Targa Blue Coupe, Original Owner,
    Duntov Award, Sam Foltz Award,
    Founders Award, NCRS Gallery VIII
    2011 Corvette Convertible
    NCRS Presidents Award 2014
    • 43219
    Re: Need GM Part Number
    Ed
    Ed------
    The original PRODUCTION valve was GM #5910602. However, that valve, also used for many earlier years, was discontinued from SERVICE in January, 1970 and replaced by GM #5910667. So, I expect that the 5910667 was the valve actually used for 1972 PRODUCTION.
    • Ed D.
      • December 1, 1990
      • 329
      Thanks Joe, I new you would have the answer. Can you tell me if POA 5910667 has a super seeded number? Can you relate to a 5910594 Valve
      Thanks again for all your knowledge and support
      Ed
      Ed DiNapoli
        • 43219
        Ed
        Ed------
        GM #5910667 was superseded by GM #5910593. The latter was then superseded by GM #6551430 which was discontinued without supersession some time ago.
        The GM #5910594 was applicable to most 1966-73 passenger cars, Camaros, and Vega as well as most equivalent Pontiacs and Oldsmobiles. It was superseded by GM #6551429 which was discontinued without supersession. How these valves functionally differ from the Corvette valve I do not know. However, I'm sure they differ in some way.
        • Peter M.
          • May 30, 2013
          • 358
          Ed,
          The difference between the 5910593 and 594 is the configuration of the ports on the POA valve.
          If you are ordering on line be very careful, many sellers don't properly identify their valves.
          If you need a photo of a 5910602 let me know, I have a NOS one for my 67.
          Kind regards
          • Ed D.
            • December 1, 1990
            • 329
            Joe, great information which I can use in identifying a new POA if necessary.
            Peter, Thanks for the offer, but I have the original valve from my 72 to compare. The problem is that the valves do not have the part numbers on the valve, so when someone has a picture of a valve you cant tell its part number.
            Appreciate all the information
            Ed
            Ed DiNapoli
            • Larry M.
              • January 1, 1992
              • 2688
              Ed:
              You tell the valves apart by their configuration. There are three (3) basic configurations regarding the ports along the sides of the valve.
              Often referred to as A - B - C configurations.
              Not certain you will find a NOS POA with the part number you want.........so you may have to settle for a GM replacement with the proper configuration. Your original valve can also be rebuilt by Classic Auto Air in Florida, and after rebuilding should operate as new.
              You can remove part numbers and dates from the replacement valves and have ink stamps made for whatever you want the part and date to be.
              Probably Classic Auto Air and Pacecar Jeff are the two folks you would want to contact regarding sourcing of the 0667 valve, if it is out there they will know where. But a bette/more practical alternative is having yours rebuilt or finding NOS replacement and making the ink stamps.
              Larry
              • Peter M.
                • May 30, 2013
                • 358
                Ed,
                The last three digits of the part number are usually ink stamped on the valve. I think 15-51 is the short number for the 5910593.
                Regards
                • Larry M.
                  • January 1, 1992
                  • 2688
                  Originally posted by Peter Miller (58508)
                  Ed,
                  Regards
                  That is correct...............and it is probably the one he needs/will find NOS. But he needs to verify before purchase.
                  Larry
                  • Ed D.
                    • December 1, 1990
                    • 329
                    The fact that the last 3 digits are the makings on the valve is interesting. The last four digits on my valve is 0602, which is the number Joe reported was the valve from 1970.
                    Thanks to all
                    Ed
                    Ed DiNapoli
                      • 43219
                      Thanks to all
                      Ed
                      Ed------
                      It's possible the GM #5910602, 5910667, and 5910593 are the same valve. It could be that the 5910602, the valve supposedly used in PRODUCTION and initially available in SERVICE, was the same valve available under the other two part numbers but some other parts or instructions were included with the other part numbers. That would explain why the 5910602 is shown in PRODUCTION through 1972 but was discontinued from SERVICE and superseded in 1970.
