jacking - NCRS Discussion Boards
jacking
  • Jeffrey G.
    Infrequent User
    • April 22, 2016
    • 19
    jacking
    Using a floor jack is it OK to raise the back of my 64 by the diff. and the front by the forward frame cross member?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: jacking
    Better in the front to jack on the lower a-arm. The crossmember will dent if you jack under it.
      • 6950
      Re: jacking
      Jeff I have jacked the rear of the corvette on the leaf spring pad, and then install jack stands on the frame.Be careful of the fiberglass spare tire tub.
        • 43259
        Re: jacking
        Jeffrey------
        You can use a jack on the front crossmember IF you jack against a thick board that spans the width of the crossmember.
        • Michael F.
          • 745
          Re: jacking
          Joe is 100% right I have been doing this on c2 and c3 since 1970 and have NEVER dented the cross member or damaged rear pad
          Michael
          70 Mulsanne Blue LT-1
          03 Electron Blue Z06
            • 15706
            Re: jacking
            I never done any damage raising the back of my SWC with a small floor jack by the strut rod bracket with a short piece of 2 x 4 between the bracket and jack puck. Same with the front cross member. Place the jack near the forward end of the member so the load is picked up the front vertical section.
            • William F.
              • June 9, 2009
              • 1364
              Re: jacking
              All those methods may be OK, But Chevy Chassis Service manual doesn't recommend them. There's a diagram showing suggested jacking locations near front of manual.
                • 43259
                Re: jacking
                William------
                Yes, the service manual jacking locations are definitely the best locations. If raising one corner of the car is all that one wants to do, they are definitely the way to go. However, if one wants to raise either the complete front end or rear end, then using the recommended locations requires the use of multiple jacks. That's the problem. In addition, if jack(s) are used at the recommended locations, then those locations are thus not available for jack stands which should always be used when the car is raised.
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Re: jacking
                  Jacking the rear to raise both wheels works just fine...avoid the jack saddle cracking the spare tire tub, chock the front wheels as the parking brake is ineffectual with the rear wheels in the air and avoid running the engine in gear with the rear wheels raised and the half shafts over-extended...
