C2 Where to find Clock adjustment gear - NCRS Discussion Boards
  • Hans R.
    • March 1, 1976
    • 91
    I've searched the forum but can't find this info....
    Where can I buy the tiny clock adjustment gear for a C2 (1965) model?
    Hans Ryden #868
  • Russ S.
    • April 30, 1982
    • 2162
    Re: C2 Where to find Clock adjustment gear
    Check with the fellas that repair clocks such as Clocks by Roger.
    • Phillip M.
      • September 30, 2006
      • 100
      Hans,
      Contact Instrument Services, Inc. at 815-623-2993, or Google them for website info. They supply many replacement parts for the Borg elec. clock movements. However, even if they can supply you with a replacement adjustment gear, you will have a challenge replacing it. The problem is that this gear is staked into the brass mounting plate and will require care in staking in a new stud (you will also need to buy a new stud).
      Phil
      • Hans R.
        • March 1, 1976
        • 91
        Thanks Russ.
        I got a reply from Roger that he has the gear.
        I also found "The Clock Works" which has the gear (or pinion).
        Thanks for your help!
        Hans Ryden #868
        • Hans R.
          • March 1, 1976
          • 91
          Originally posted by Phillip Martinez (46331)
          Hans,
          Phil
          Hi Phil,
          Replacing the gear is not a problem, my friend has been restoring automotive clocks for ages and have done this job on Corvette
          clocks.
          Thanks for the hint on contacting Instrument Services, Inc.
          Hans Ryden #868
