Lifter tap on 1973 454 - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4540
    Re: Lifter tap on 1973 454
    Originally posted by Peter Gregory (4157)
    My '73 LS4 cracks valve spring nuts. Has done it three times in the last ten years. A retired Chevy parts manager told me that I should carry half a dozen of these nuts in the car with me. They are just $1 each. He said these big blocks break these nuts all the time back in the day.
    That was the fix when the engine started tapping.
    Do you mean rocker arm nut?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Peter G.
      • December 1, 1980
      • 406
      Yes. Holds the rocker arm down.
      Thanks.
      Peter Gregory # 4157
      National Corvette Restorers Society Since 1980
      • Mark E.
        • April 1, 1993
        • 4540
        #18
        The only failure I've encountered with the nut are worn threads. Since they are friction threads, they can lose their tension if adjusted a lot.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Bruce C.
          Infrequent User
          • December 1, 1988
          • 13
          #19
          If the problem turns out to be a noisey lifter,most lifters can be replaced on a big block without intake removal.Remove the valve cover,and you will see numerous access holes(large),remove push rod,using a strong magnet,pull the trouble lifter out of the bore.If the lifter is varnished up, wash with 2 plus 2.Sometimes they can be a fighter to get out of the bore,but rotating and pulling and you will be able to extract it.Also make sure the fuel pump lever is not loose.
