Lacquer paint - NCRS Discussion Boards
Lacquer paint
  • Walter F.
    • October 22, 2006
    • 373
    Lacquer paint
    When did Chevrolet stop painting Corvettes with lacquer paint. Must lacquer paint be used on Corvettes that originally were painted in lacquer for judging?
    • 43247
    Re: Lacquer paint
    Walter-----
    As far as I know, the last Corvette painted with lacquer paint was the last one (1981) built in St. Louis.
    Assuming that a judge can discern the difference, I believe there is a judging penalty for a Corvette originally painted with lacquer which is re-painted in non-lacquer.
    • Bob R.
      • June 30, 2002
      • 1595
      Re: Lacquer paint
      The rules have changed in judging paint and there are now standard deductions but it is all based on appearance. If the car appears as it left the factory full credit is given for the paint regardless of the type of paint used. If the car is base coat clear coat and wet sanded smooth then buffed it could take a full deduction but if it is left with some texture it can get full credit or at least partial credit depending on the appearance. Areas like the door openings and hood ledge should be dull.
      • Domenic T.
        • January 29, 2010
        • 2452
        Re: Lacquer paint
        GM used 2 kinds of lacquer. They started with lacquer then went to acrylic lacquer. Acrylic wasn't my favorite of the 2 lacquers.
        Dom
        • Stephen R.
          • May 20, 2008
          • 302
          Re: Lacquer paint
          I kind of remember an "enamel" type paint being used on cars in the 50's and 60's. Don't know if it
          was ever used on a vette since it needed to be "baked' on. But it was supposed to be harder and more durable than lacquer.
          • Domenic T.
            • January 29, 2010
            • 2452
            Re: Lacquer paint
            Stephen,
            Synthetic automotive enamel. It couldn't be recovered after a few hours and shops would do a wipe down if they ran the paint. Never saw it on GM but it did have a great finish and lasted.
            Dom
              • 43247
              Re: Lacquer paint
              Dom
              Dom------
              The lacquer paint used on early Corvettes was called nitrocellulose lacquer. I don't know when that changed to acrylic lacquer but I think it was rather early in the C1 era.
              • Domenic T.
                • January 29, 2010
                • 2452
                Re: Lacquer paint
                Joe,
                I remember acrylic lacquer being used when the metalic paint came out. From what I remember they said "no need to use clear over acrylic" it has acrylic that sets up over the pigment. Spider web and what we called in the midwest "paint check" seemed to follow in a few years outside.
                I loved acrylic enamel when it came out. Went on like lacquer, could be rubbed out and lasted. I believe its formula is now the base coat on the BC CC.
                Dom
                  • 43247
                  Re: Lacquer paint
                  Joe,
                  Dom
                  Dom------
                  Yes, as far as I know, no clear coat was ever used in conjunction with acrylic lacquer on a Corvette.
                  • Dick W.
                    • 10483
                    Re: Lacquer paint
                    Dom------
                    First ads I remember for acrylic was in 1957 and the firemist Cadillac colors
                    Dick Whittington
                      • 15706
                      Re: Lacquer paint
                      I think the first Corvette acrylic lacquer was Inca Silver in 1957. By '58 or '59 all GM cars were painted with acrylic lacquer, but I believe light trucks were painted with alkyd enamel.
                      • John D.
                        • June 30, 1991
                        • 875
                        Re: Lacquer paint
                        I believe GM used acrylic lacquer well into the 1980's
