Spare Tire Wheel Weights - NCRS Discussion Boards
  • Dan L.
    • May 9, 2012
    • 97
    For the purpose of NCRS Judging does the spare tire/wheel in my 66 need to have wheel weights? Thanks
    Dan
    54915
  • Michael M.
    • February 1, 1993
    • 606
    Re: Spare Tire Wheel Weights
    It really does not need a wheel weight unless the wheel with the tire mounted is out of balance. I do believe that the judges like to see a weight on the wheel.
      • 6958
      Dan, it may depend upon the judge. it is possible that the wheel may not of had a weight, but if it were me I would put something on the wheel. even if its not balanced correctly.
      • Dan L.
        • May 9, 2012
        • 97
        Thanks Ed and Mike - will add a correct weight for judging.
        • Leif A.
          • August 31, 1997
          • 3654
          I wouldn't. If you feel rather certain that this is the original wheel and tire that came with your car I would leave it completely "as is". Especially, if there is no indication that a wheel weight may have at one time resided on the interior rim. Don't add a weight "just cuz"...there are many instances of tires balancing out without any weight whatsoever. You should not (and, probably will not) get a deduction.
          Leif
          • Jimmy G.
            • November 1, 1979
            • 977
            Short Answer ---- YES
            • Gary B.
              • February 1, 1997
              • 7075
              Originally posted by Leif Anderson (29632)
              ...there are many instances of tires balancing out without any weight whatsoever...
              Leif,
              What's the basis for your statement, specifically for original '66-era tires and wheels? My guess is that almost no '66-era tire and wheel was close enough to the GM spec to require no balance weights.
              Gary
              • Leif A.
                • August 31, 1997
                • 3654
                Originally posted by Gary Beaupre (28818)
                Leif,
                Gary
                Gary,
                When I was a senior in high school (1966-1967) I worked in a tire store, part time, mounting and balancing tires. Most required some amount of added weights to correctly balance, but I can remember many instances when a tire wheel combo didn't require any weight at all to balance correctly. There used to be a paint dot on these old tires and I was always told that if you align the paint dot with the valve stem, the tire/wheel combo would require the least amount of added weight. Have no idea if there was any validity to this, but I always balanced that way. Just my experience.
                Leif
                • Michael J.
                  • January 27, 2009
                  • 7169
                  +1, agree, and make sure they are Micro weights with ounces marked on both ends.
                  • Dan L.
                    • May 9, 2012
                    • 97
                    Thanks guys for your advise an guidance. One more quick question - although I have the steel wheels and bias ply tires I run it on direct bolt knock offs. Are the lug nuts interchangeable.
                    • Gary B.
                      • February 1, 1997
                      • 7075
                      Although Micro logo weights made by Bada are perfectly acceptable, so are 3 or 4 other logos/manufacturers if you happen to find them. My article in the Restorer from a few years ago shows photos of most logos that are C2 & C3-era correct. For C3s, it's possible that Micro was not the most common logo weight used.
                      Gary
                        • 15706
                        All wheel/tire assemblies were static balanced by St. Louis with any necessary weight placed on the inside of the wheel, only. In all my years of installing tires on my cars I recall one instance where the assembly was in "perfect" dynamic balance and did not require any weight added on either side. I think this situation is very rare, so installing a small weight of proper configuration would likely not lead to any questions by the judging team.
                        If you know of a shop that has an old-fashioned "bubble balancer" that only static balances the assembly, it's probably worth the small cost to have it static balanced.
                        • Ed D.
                          • December 1, 1990
                          • 329
                          Had points deducted for no wheel wts at a National
                          Ed
                          Ed DiNapoli
                          CNJ Chapter Past Chairman/Co Founder
                          1972 Targa Blue Coupe, Original Owner,
                          Duntov Award, Sam Foltz Award,
                          Founders Award, NCRS Gallery VIII
                          2011 Corvette Convertible
                          NCRS Presidents Award 2014
                          • Harry S.
                            • July 31, 2002
                            • 5345
                            When I judge exterior I look for 2 or 3 of the 5 to have weights. I had my five 63 steel wheels straightened. Another shop mounted the tires and added the weights, only two wheels needed weights the other three were fine. Saying that, it is possible to not need any weights. Seeing all five without weights raises a red flag.
                            • Don B.
                              • January 3, 2017
                              • 24
                              Where in the world would you find the correct weights for a C3?
