spare tire carrier mounting bolts "L" head. - NCRS Discussion Boards
  • Paul L.
    • July 7, 2015
    • 38
    I have seen bolts advertised with an "L" head, can anyone comment on whether these bolts could be correct and what C2 year would be applicable? Thanks
    • 6948
    Re: spare tire carrier mounting bolts "L" head.
    Paul, there were many suppliers for mid year the spare tire carrier bolts, I have seen no head mark bolts, and RBW, E, I would also say that L was another. 5/16 x1" recessed hex head with a separate washer.
    • David H.
      • June 30, 2001
      • 1544
      Paul
      Photo would help. Are you asking about long bolts with four sided head consisting of two straight flats and two “round” ends?
      Dave
      • Paul L.
        • July 7, 2015
        • 38
        No Dave, I'm talking about the 4 short mounting bolts.
        • Paul L.
          • July 7, 2015
          • 38
          Thank you sir. I've seen EW and D as well as the two you mentioned. I thought L were also used, but good to know. The 6th Guide only mentions E and EW. My fear is they will only credit the two mentioned in the guide.
          • Michael M.
            • February 1, 1993
            • 604
            The head mark I see a lot on original cars is " D " with fine thread.
              • 6948
              Paul, those bolts likely do not have much point value. and most judges would except the repro bolts. if anything deduct there may only be 1pt., it all depends on the point value that the judge places on hardware, the hardware may also inc. the tub hanging hardware.
              • Mike B.
                • July 31, 1994
                • 843
                My '65 had bolts there with 3 raised dots. Original to the car. VIN #140XX.
                Mike
                • John M.
                  Infrequent User
                  • August 31, 1994
                  • 21
                  Carrier bolt + washer off my unrestored 1967, 45K miles, Jan 67 build, no head markings
