62 stamped date - NCRS Discussion Boards
62 stamped date
  • Roger B.
    • June 30, 1991
    • 82
    62 stamped date
    1962 I have a build date 04/16 with a casting date of 03/28
    on a 62
    is this possible?
    thanks
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 62 stamped date
    seems reasonable. . i assume the casting date is 3 28 2, not 3 28 62. mike
    • Roger B.
      • June 30, 1991
      • 82
      Re: 62 stamped date
      Mike
      it is F0328RD
      • Mike M.
        • May 31, 1974
        • 8400
        Re: 62 stamped date
        Fo328RD isn't the cast date, its the machine assembly date. casting date embossed on pass side of block on bell housing flange of block. mike
        • Mike E.
          • February 28, 1975
          • 5141
          Re: 62 stamped date
          Roger,
          Back up a bit. Build date of what? If that is of the car, it is a best guess—usually within a day or two.
          If F0328RD, that is the build date (usually referred to as the assembly date) of the motor at Flint.
          That gap (from March 28 to approx. April 16) is not an inordinate gap. Very acceptable.
          Would be interested in knowing the casting date on your block. As Mike said, on right rear near where bellhousing attaches.
          • Roger B.
            • June 30, 1991
            • 82
            Re: 62 stamped date
            Sorry for questions
            casting is C222
            vin 9855
            thanks for info
            • Mike E.
              • February 28, 1975
              • 5141
              Re: 62 stamped date
              No reason to be sorry. A very valid question. What you have sounds right, so you got good news!
