Re: Spring's first start up...procedure
Just want to add something else to think about. If your car is fitted with K66 Transistor Ignition you may cause damage to the circuit board when disconnecting the coil wire and cranking just to build up oil pressure. I believe the service manual specifically talks about not doing this. Maybe others can confirm this.
On my '67 L79 w/K66, the carburetor bowl evaporates when sitting for more than a week. I just crank until the bowl is full which takes about 30 seconds. In that time oil pressure builds and the bowl fills. Then one or two pumps on the accelerator sets the choke and squirts enough fuel to fire the engine.
Rocco S.
Rocco S.
