Help identifying these ground straps - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
    Guys,
    Can anyone help me identify these ground straps and where they might go?
    Mike
  • Alan D.
    • January 1, 2005
    • 2054
    Re: Help identifying these ground straps
    See your AIM, for 1964 it's page: sect. U69 sheet 5.00, radio ground straps.
    We need a little more info, is it for a C2 (what year) some dimensions would help.
    Possible - two larger ones for exhaust clamp to frame, small one is body mount 2 to bird cage,
    other no idea.
    • Russ S.
      • April 30, 1982
      • 2163
      The "other" looks to be the one from the engine frame horn to motor mount.
      other no idea.
      • Leonard M.
        • September 7, 2009
        • 236
        Here's the small one with the clip on a '70
        • Gene M.
          • April 1, 1985
          • 4233
          Left to right accelerator linkage, birdcage to front body mount of frame, last two exhaust to frame
          • Michael L.
            • December 15, 2006
            • 1424
            • Russ S.
              • April 30, 1982
              • 2163
              That changes things!
              • Michael L.
                • December 15, 2006
                • 1424
                How so Russ?
                • Russ S.
                  • April 30, 1982
                  • 2163
                  If you were talking about a C2 the first strap could be as I stated. If you are referring to a C3 it couldn't be as C3 doesn't use that type of strap for the frame to engine. C3 used a large cable similar to a battery cable for the frame to engine ground.
                  Originally posted by Michael Leonard (46610)
                  How so Russ?
