The 67 TIM/JG outlines how the cotter pins at the strut rod/shock mount connection are to be installed - from the bottom with the longer leg bent back over the stud and castle nut and THE OTHER HALF REMAINING VERTICAL. Fine and dandy. No comment is made about the cotter pins at the bottom of the long bolts connecting the ends of the leaf spring to the rear of the trailing arms.
Obviously those two pins are installed horizontally, but are they also supposed to be bent in a certain manner for judging? Thanks.
Rick
Rick
