1972 Spare Tire Carrier Bolt Size - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    I'm getting ready to remove the spare tire carrier to freshen it up a bit. What is the trick to getting the two front bolts off since it does not have a conventional bolt head. Thanks!
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Michael G.
    • March 2, 2008
    • 487
    Re: 1972 Spare Tire Carrier Bolt Size
    The round heads should have 2 squared edges that would allow an open end wrench to fit.
    • Jack C.
      • 1090
      Thanks. I did see that, I was just wonder if there were an alternative to an open end.
      Jack Corso
      • Michael G.
        • March 2, 2008
        • 487
        I find a large adjustable wrench will put more contact surface on bolts.
        • Harmon C.
          • August 31, 1994
          • 3228
          Lots of times if you try to loosen the jam nut the whole bolt will turn.
          Lyle
