1971 LT1 Temp gauge - NCRS Discussion Boards
1971 LT1 Temp gauge
  • Donald K.
    • January 5, 2018
    • 11
    1971 LT1 Temp gauge
    I found the green wire. but the part that plugs into the sending unit is missing.
    just purchased a 71 LT1 and the temp gauge is at 100 and never moves.
    after looking under the hood, I noticed the driver side sending unit has no wire to it.
    can anyone help me on what to do to fix my problem.
    thanks
    Donnie
    • 43246
    Re: 1971 LT1 Temp gauge
    thanks
    Donnie
    Donnie------
    Well, the first thing you need to do is to restore the wire to the temp sender. This should be a green wire that's part of the engine compartment wiring harness.
    • Donald K.
      • January 5, 2018
      • 11
      thank you
      I will be ordering the part on Monday
        • 43246
        thank you
        Donald------
        Standard Motor Products #S2292.
        • Donald K.
          • January 5, 2018
          • 11
          thanks
          Donnie
