If you have recently purchased an older Corvette, you may want to check for correct fuses even if it had a body off restoration. I have a 1966 427 425HP that had a body off restoration prior to purchasing it. The manual calls for one 15 amp, three 10 amps, one 4 amp and one 3 amp. The car had four 25 amps and two 20 amp fuses in it. Looks like the guy purchased a box of 25 amp fuses. I had an issue with the rear courtesy light. The attached photo will identify what the problem caused. I have since then installed correct fuses and/or replace/checked/repaired all my wiring. Just identifying my experience.
