Driveshaft and Half shaft restoration? - NCRS Discussion Boards
  • William G.
    • January 1, 1988
    • 220
    Who is doing drive shaft and half shaft restoration to NCRS standards? Thanks, Bill Gould
  • Dave S.
    • August 31, 1992
    • 2927
    Re: Driveshaft and Half shaft restoration?
    i believe Mike Zamora is doing them. They look great from what I have seen. If you are on any sort of budget you might need to consider another option.
    • Ron G.
      • December 1, 1984
      • 865
      Bill, contingent upon what engine is in your Corvette, ( all from 1965 through 1972) if it is fuelie, 365, big blocks, LT-1 they had their hot shafts shot peened to relieve the stress of their welds because of the torque of the high-performance engines. They were shot peened with a number (31) shot. I know of a company in east Hartford, CT that does a great job.
      "SOLID LIFTERS MATTER"
      • Michael B.
        • January 20, 2014
        • 187
        Ron,
        Were the half shafts in base engine, automatic transmission cars shot peened also? Our JG states that base engine cars used U-bolts to fasten the half shafts to the differential yoke but I know for a fact that base engine/automatic 1971 and 1972 cars used the blocks just like the BB's and LT-1's.
        The half shafts in my base engine/auto car look identical to my LT-1.
        I suspect these were shot peened but I'm curious if you know for certain?
        Mike
        • Ron G.
          • December 1, 1984
          • 865
            • 43258
            Dave------
            I don't think anyone could restore the exact original finish of any Corvette driveshaft or non shot-peened half shafts.
              • 43258
              Originally posted by Michael Brezden (59460)
              Ron,
              Mike
              Mike-----
              1968-74 base engine cars used non shot-peened half shafts, manual or automatic transmission.
              1969 L-46 and 1970-72 LT-1 MAY have used shot-peened half shafts; I can't confirm but I suspect that at least LT-1 did use shot-peened shafts.
              1973-74 L-82 used shot-peened shafts.
              Is it possible that any particular Corvette scheduled to receive non shot peened shafts actually received the shot-peened avriety? Of course.
              Stub axle type (cap or u-bolt) is related to the installed differential carrier assembly and unrelated to the type of half shaft used.
                • 15621
                1969 to 1972 M40 were supposed to get shot peened (with cap) half shafts. I think 1968 falls in there also, but I am not so sure of that. Of course, as Joe points out, they would have the HD differential.
                  • 43258
                  Terry------
                  I'm not so sure. If you look at AIM sheet M40-A2 for 1968-72 you will note no reference to "differential and axle shafts". This implies that they are the same as production. (You will note such a reference for 1970-72 LT-1, though).
                  For 1973-74 the axle shafts installed differed only as a result of installed engine. L-48, regardless of transmission, received the non-shot-peened axle shafts; L-82 and LS-4, regardless of transmission, received the shot-peened axle shafts. I don't see why it would have been essentially any different for 1968-72.
                  Of course, with respect to any particular car, could shot-peened shafts have been originally installed instead of the standard variety? Of course. Such an upgrade probably wouldn't have even required engineering approval.
                  • Ron G.
                    • December 1, 1984
                    • 865
                    Joe,
                    Believe it or not, I actually have a little over 5' of what I believe is NOS drive/half shaft tubing. As you are probably aware, 71's had a larger diameter tube for the drive shaft than the 70's. The half shafts I believed used the same diameter as 1970.
                      • 43258
                      Originally posted by Ron Goduti (8076)
                      Joe,
                      Ron-----
                      1963-70 driveshafts, except 1968-70 with M-40, were, nominally, 2" OD.
                      1968-70 driveshafts with M-40 and all 1971-79 were, nominally, 2-1/4" OD
                      1963-74 half shafts were, nominally, 2-1/2" OD
                      1975-79 half shafts were, nominally, 3" OD
                      • Michael B.
                        • January 20, 2014
                        • 187
                        I think I'll shot peen one half shaft and leave the other plain. Just kidding.
                          • 11678
                          Depending on current condition, it's possible to distinguish between the two finishes.
                            • 15621
                            Terry------
                            My observations are from looking at a whole bunch of Corvettes, but I haven't seen all of them; and I am pretty sure I won't live long enough to see them all, but I'll try.
                              • 43258
                              Terry-----
                              By the way, only the shot-peened half shaft was available in SERVICE from March, 1966 thru 1974. After that time, only the 1975+ half shaft was available for all 1963-74 SERVICE.
