Did the Split Window Coupe have a prototype? - NCRS Discussion Boards
  • Patrick T.
    • September 30, 1999
    • 1286
    Maybe like this one? Thanks
  • Dick W.
    • 10483
    Re: Did the Split Window Coupe have a prototype?
    Dick Whittington
    • David R.
      • June 29, 2014
      • 183
      This is the Oldsmobile Golden Rocket concept car, built for the 1956 GM Motorama. Also known as XP-400 / SO 2490. It is very well-documented and often photographed - a handout brochure was even prepared for it. And while it does carry a split rear window, and was even considered as a possible future Corvette styling theme for, say, 1958 or so - it wasn't really a prototype for the 1963 Sting Ray. The styling for that car was lifted from Bill Mitchell's 1959 Sting ray racing car, built on the Corvette SS mule chassis.
      • Patrick T.
        • 1286
        Thanks for your informative comments........I think!
          • April 1, 2000
          • 477
          While similar to the Olds Golden Rocket, the above car is different. Here is a link to a pic of the Golden Rocket 1956 Motorama car:
          https://i.pinimg.com/originals/f7/56/28/f756289da91288e0af4c9191eb5a70a4.jpg
          The car in post #1 is claimed to be a circa 1956 clay model prototype for the 1958 Corvette and based on the Olds Golden Rocket Motorama car as suggested in this wiki entry:
          • David R.
            • June 29, 2014
            • 183
            You're right, Jack - I should have clarified a bit better. The car shown is not the actual 1956 Olds Golden Rocket, but a styling clay based on that car as a possible styling direction for the 1958 Corvette. The front end of the clay is quite different from the Golden Rocket.
              • 11653
              You've likely read the books, but what is known as the Q Corvette is as close to a Sting Ray predecessor as any other car.
                • 15696
                The original design concept was developed by Bertone for the Alfa Romeo series of BAT concept cars, beginning in 1953.
                • David R.
                  • June 29, 2014
                  • 183
                  While some of the Bertone Alfa Romeo BAT cars did feature a split rear window, I think it's a huge leap to say that any of them were "the original design concept" for the 1963 Corvette.
                  • Richard L.
                    • December 4, 2009
                    • 166
                    And the VW Bug had a split window from 39-53. So not a new concept, but what really inspired the 63 Vette?
                    • David R.
                      • June 29, 2014
                      • 183
                      I would say that Patrick is right - the so-called "Q-Corvette", which dates from 1957, is probably the closest to an actual concept 1963 Sting Ray.
                      • James G.
                        • May 31, 1976
                        • 1556
                        As the Vice President of Design at GM, Bill Mitchell asked his design team in 1957 to create a car that was โ€œa complete breakaway from what weโ€™ve seen around here in the past.โ€ The sketches he received moved away from the rounded forms that were in vogue since World War II. Peter Brock, a young designer who later garnered fame designing the Shelby Cobra Daytona, had a sketch that caught Mitchellโ€™s fancy and was selected for further development. Larry Shinoda took this design to another level and created the 1959 Stingray Racer XP-87. The XP-87 eventually evolved into the production Corvette Sting Ray for 1963.
                        PETER BROCK actually created the original design. Bill Mitchell liked it and had LARRY SHIONDA take it to the finished car level. 1957 until 1963.. READ PETER'S BOOK
                        • James G.
                          • May 31, 1976
                          • 1556
                          • Jaime G.
                            • April 1, 1988
                            • 480
                            well stated Jim. It was a design Brock generated and Shinoda perfected.
                            • David R.
                              • June 29, 2014
                              • 183
                              All good (and true) comments . . . but the original question was not "Who designed the SWC?". It was "Did the SWC have a prototype?". Two very different questions. And the "Q - Corvette" appears to come closest to fulfilling that role, even if it was only a model and not a running car.
                              And yes, anyone who has not read Pete Brock's excellent book should definitely do so.
