Routing of Brake Low Pressure Switch Wire - NCRS Discussion Boards
  • Rick R.
    • February 10, 2015
    • 142
    Is here a specified/correct routing of the tan wire from when it exits the harness to its connection to the low pressure switch? Thanks.
    Rick
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11356
    Re: Routing of Brake Low Pressure Switch Wire
    AIM UPC 12 Sheet A10 shows the Tan wire running along the harness and into the harness firewall clip and later taped to the harness before getting plugged into the switch.
    But I recall the Tan wire is not long enough to reach the clip as it leaves the harness after the clip.
    This is what it looks like on the last car I worked on...
    • Rick R.
      • February 10, 2015
      • 142
      Richard, thanks very much for your post. On this car, there is plenty of wire length, put the wire had not been routed through the firewall clip, but via a different route. I suspected it was supposed to use the clip, but was uncertain. Another item crossed off of my to do list. Thanks again.
      Rick
