59 Corvette clutch/flywheel shield? - NCRS Discussion Boards
  • R K.
    Infrequent User
    • March 1, 1980
    • 7
    I am working in the engine compartment cleaning, painting, etc. (engine/transmission are out) and there is a "shield" made out of about 3/16" steel bolted to the fiberglass above the clutch area. I don't see this anywhere in my assembly manual and noticed that the bolts are stainless - - - definitely not factory. Is this supposed to be there? It is very well made and looks factory but I am just not sure.
    i searched both this forum and the internet and haven't been successful in finding a picture or info.
    Help.
    thanks,
    Reggie
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 59 Corvette clutch/flywheel shield?
    Sounds like someone's attempt at a scatter shield. Any possibility for a photo??
    Leif
    • R K.
      Infrequent User
      • March 1, 1980
      • 7
      That's what it looks like to me also. Not sure why they would do that since the motor wasn't hopped up with anything special but based on the way it was made I'm just not sure.
      I will get some pics tomorrow and post.
      Thanks for the response.
      Reggie
      • Don H.
        • December 1, 1981
        • 1496
        It about has to be a scatter shield. I installed a scatter shield (bought from an ad in the Driveline) in my '60 years ago because I drag race it. Although I have never personally seen a cast flywheel explode, I have seen pictures, it is not pretty. Only having an aluminum bell housing and fiberglass body between the flywheel and your legs is not a comforting thought when routinely dropping the clutch at higher RPM's. I will probably remove it when I restore the car. Good luck, Don H.
        • Don H.
          • December 1, 1981
          • 1496
          Here are a couple of pictures of mine. Don H.
          • R K.
            Infrequent User
            • March 1, 1980
            • 7
            I have attached three pictures of the shield. For one picture I put it loosely back in place - - not tightened up.
            It was painted black but very rusty so I blasted it with some other frame parts.
            I get a sense from the comments that this is NOT a factory piece so I will not be putting it back on.
            Reggie
            • Leif A.
              • August 31, 1997
              • 3654
              Definitely not factory...
              Leif
