1981 tach not working - NCRS Discussion Boards
  • Keith G.
    • October 31, 2006
    • 316
    What is the first thing that goes wrong on a 81 tack, where do I start????
  • David H.
    • June 30, 2001
    • 1559
    Re: 1981 tack not working
    Keith,
    Ground - First thing to check. Next would be connection at distributor.
    Dave
    • Tom R.
      • June 30, 1993
      • 4102
      After the easy stuff, target the tach board. It's said that 90% of the time the culprit is the tach board. Those originals used think copper paths that burned out over time and components not as stealthy as those today. Below is link to an article written probably ten years ago and has relevance today. To replace in an 81 is easy compared to a 75-77 where the dash has to be removed. I've replaced a couple.
      Tom Russo
      78 SA NCRS 5 Star Bowtie
      78 Pace Car L82 M21
      00 MY/TR/Conv
      • David H.
        • June 30, 2001
        • 1559
        Keith,
        I believe your 1981 uses a computer (ecm) controlled carburetor. ECM receives a tachometer signal as one data input. Is that system still functioning?
        Dave
          • 43272
          Re: 1981 tach not working
          Keith-----
          It could also be the tach filter. These are also well known for failure. It was GM #14020025 but it's long-since GM-discontinued. I don't know of a replacement source but there may be one by now.
          • Keith G.
            • October 31, 2006
            • 316
            Keith-----
            John, paragon said to try to by-pass the filter, so I did, didn't fix it, but did wake it up. It was stuck on 1200, now when I turn the key on it goes to 0, with the motor at idle it goes to 750, give it some gas and it will slowly make it's way to the right RPMs, back off and it goes back to the 1200 at idle (which is wrong), tap on the dash and then it goes to 750.??????
            • David H.
              • June 30, 2001
              • 1559
              Keith,
              You might find some useful information in link below with connections.
              Dave
              • Tom R.
                • June 30, 1993
                • 4102
                Tach board!
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                  • 43272
                  Originally posted by Tom Russo (22903)
                  Tach board!
                  Tom and Keith------
                  GM #25023527. Discontinued but reproductions are available.
                  • Tom R.
                    • June 30, 1993
                    • 4102
                    Tom and Keith------
                    Yeah...I tested one for Wilcox (made in USA) who reproduces those with new components and better than what was coming out of China! My Pace Car has a Wilcox in it.
                    Tom Russo
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
