67 trico wiper blade rubber inserts - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3161
    I've looked thru the past threads about 67 Trico wipers and could not find a definitive answer about the rubber inserts.
    Does anyone have a photo of a correct Trico rubber insert. The new judging manual does not have a photo showing this either.
    Steve
    EDIT: I've included photos of my inserts. Are these correct for 1967 Trico wipers?
  • Stephen L.
    • May 31, 1984
    • 3161
    Re: 67 trico wiper blade rubber inserts
    Steve
    Found this description about 67 Trico blade rubber inserts from Pete Lindahl in an old thread...
    Rob - First, yes the "original" ANCO rubber wiper had ANCO plus a patent number, 2782444, embossed on them.
    Second, the "original" 15" 66-67 TRICO rubber wiper has the 3 horizontal ribs but does not have TRICO on it but it does have several US and CAN patent number embossed on the top of the rubber wiper plus the words PATENT PEND. The wiper blade refill has a "slideable Latch-Lock with clasping at one lever end"and a metal vertebra with 23 "backbones."
    Hope this helps, but if you need more gory details, let me know. Pete
    I believe Pete's description fits my photos of the inserts perfectly for 67 Trico wiper rubber inserts
    • Peter L.
      • May 31, 1983
      • 1930
      Steve - The refills/inserts in your photos are typical of the TRICO 15" Wiper Blade Refills with the stainless steel vertebra & Latch-Lock clips & the rubber wiper element w/the 3 lines that I would expect to find on a '67 Corvette w/TRICO wiper blades for judging. Pete
      • Stephen L.
        • May 31, 1984
        • 3161
        Thanks Pete.
