Best way to remove paint from spare tire cover - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1391
    Guys,
    Trying to clean up the spare tire cover on my 69 coupe. A previous owner had painted it rattle can black. My first thought was to carefully use paint remover, doing small areas at a time and not letting it sit too long. What do you think?
    Mike
    • 6942
    Re: Best way to remove paint from spare tire cover
    Mike just do not use any paint stripper, use fiberglass paint stripper. or try some lacquer thinner and fine steel wool .
    • James W.
      • December 1, 1990
      • 2658
      Mike,
      There was a like post a few weeks ago about removing paint from a C2 spare tirecover and the general consensus was to use lacquer thinner and a rag orpossibly the softest 3M Scotch Brite pad that they make.
      James
      Originally posted by Michael Leonard (46610)
      Guys,
      Mike
        • 11644
        Lacquer thinner or acetone. They work quite well.
        Interestingly enough, I've also recently had good results with WD-40.
        • Michael L.
          • December 15, 2006
          • 1391
          Thanks guys.
          • Richard F.
            • September 30, 1981
            • 498
            An old sign painters trick, use oven cleaner it also removes "traded paint" I used it often when I was in the part time used car business. it never harmed the original paint.
            Thanks guys.
