67 427 Valve Cover Bolts - NCRS Discussion Boards
  • David G.
    • December 1, 2002
    • 99
    Is it normal that you would have a mixture of the possible valve cover bolt head markings on the same car?
    • 6942
    Re: 67 427 Valve Cover Bolts
    Dave I would say yes, GM brought bolts from several manufacturers. just make sure they are generation correct ones.
    • Keith B.
      • September 15, 2014
      • 1583
      and the correct length. If I remember correctly the ones that hold the spark plug ground wire is longer then the other ones
      • Joe R.
        • July 31, 1976
        • 4551
        I certainly agree with the above but NCRS judges on TYPICAL and I would say a mixed set of Valve cover bolts would not be TYPICAL so you had better direct this question to the 1967 Team Leader Nick Culkowski. He will have the final say.
        JR
