Foam door seals for window and wing cranks on c2 - NCRS Discussion Boards
  • Daniel B.
    • September 12, 2017
    • 45
    Do the foam seals for a 64 C2 go on under the vapor barrier or on top of the barrier. My car had neither seals or vapor barriers installed.
    Dan
    • 6956
    Re: Foam door seals for window and wing cranks on c2
    Dan, I installed my foam seals on the outside of the vapor barrier.
    • James W.
      • December 1, 1990
      • 2673
      Daniel,
      I concur with Edward, same on my '64 convertible.
      James
      • Daniel B.
        • 45
        Just for justification, is "outside of the vapor barrier" placing it between the vapor barrier and the interior door panel?
        Dan
          • 6956
          Dan, yes, outside the vapor barrier
          • Daniel B.
            • 45
            Thank, that's what I thought but my post could of been missintreited as to what was outside versus inside. I'll try to be more explicit next time.
