1987 Convertible Antenna Relay direction? - NCRS Discussion Boards
  • Eric J.
    • March 1, 1980
    • 771
    I need help. I am restoring the factory antenna in my 1987. The PO decided to put a generic antenna in and removed the relay. Does anyone know what part of the relay faces forward?
    Eric
  • Eric J.
    • March 1, 1980
    • 771
    Re: 1987 Convertible Antenna Relay direction?
    *bump* anyone have any thoughts. 86's have it in the same spot too.
    • Eric J.
      • March 1, 1980
      • 771
      Dave, Thanks for the reply. Here is a picture of what I think is the mount.
      The relay can be clocked in either direction and the wiring is more or less in the same location. I'm hoping someone can take a peak at their 86/87 and let me know. Otherwise I will just mount it rightly or wrongly ( I guess I have a 50% chance of being right!)
      Eric
      • Eric J.
        • March 1, 1980
        • 771
        Thanks Dave, I found an original relay on ebay that I'm waiting to get. The one I have is a service replacement without the metal mount so I can't tell yet. The PO removed everything when the generic went in.
        After thinking about your post, perhaps the relay pictures above is for the coupe. The convertible may have a mount that's bent 90deg to the one pictures. It appears from the Electrical Service manual the relay connectors point towards the rear of the car.
        • Eric J.
          • March 1, 1980
          • 771
          I mounted the relay as it appears in the electrical service manual "Figure C" above. I did end up bending what appears to be the coupe mounting bracket 90deg. The wires tuck nicely into a little valley on the back bulk head.
          Works great now!
          Thanks Dave for the help
