95 LT1 Does the owners manual packet come with penlight or tire gauge - NCRS Discussion Boards
  • Chris G.
    • October 22, 2006
    • 94
    Hi, the manual says it comes with a tire pressure gauge if it has spare tire delete, but it doesn't say if it does not have spare tire delete is the tire pressure gauge replaced with a pen light? Also what does the GM protection Plan agreement and VIN card look like? It also says warrranty booklet? I wish there was a picture of all these items. If anyone knows the answer or can post a picture of a complete kit I would appreciate it. The owners paperwork seems to be the only items lacking on my car.
    Thanks!
  • Ken R.
    • August 31, 1980
    • 305
    Re: 95 LT1 Does the owners manual packet come with penlight or tire gauge
    here is what was with my 95. Pen light.
    • Chris G.
      • October 22, 2006
      • 94
      Thank you! I am missing more than I thought! I dont have the fuse, keyless entry sticker, or the parking brake sticker. IF you have a chance could you snap an up close photos of those and email corvette95@gmail.com THANK YOU!!
      • Floyd B.
        • November 1, 2002
        • 1046
        You might want to note that this no longer a judged item. It is roughly equivalent to the "POP" of the C2 and C3 generation. Look for my post near the bottom of this linked thread. It references the Judging Chariman's message in the Restorer that discontinued this practice.
        https://www.forums.ncrs.org/showthre...7-Key-Envelope
        "Drive it like you stole it"
        • Chris G.
          • October 22, 2006
          • 94
          I was hoping you could tell me. I was reading it from the Judging Guide! I have gotten mixed photos of what the roadside assistance brochure and emergency/courtesy key looks like. I have seen two different versions from a known 95 .
          • Floyd B.
            • November 1, 2002
            • 1046
            Chris,
            This is what I have collected for my '96. None of these are original to the car. You will have to perform research as to whether they are applicable to your car. Notice the Roadside Assistance pamphlet is dated 1994. I believe it is correct for both '95 and '96.
            You need to do some research but I have been told that certain '95's should have had this DexCool notice. It's a 4-page folded pamphlet printed on a single piece of card stock - pages 1 & 4 (opposing each other) on one side and pages 2 & 3 printed on the other side, then folded down the middle.
            DexCool.pdf
            • Chris G.
              • October 22, 2006
              • 94
              Thanks, the pictures help. Your roadside is one of the two I have found, I DON'T think it is the OE one but am not sure. The key pics really helps as well. I am going to try to attach other possible variable brochure for 94-96.
              • Chris G.
                • October 22, 2006
                • 94
                If anyone has the above brochure for either sale or can provide high resolution copy- front and rear- it would be greatly appreciated
                Chris
                • Ed N.
                  • May 16, 2010
                  • 998
                  Chris, the fuse and the parking brake decal are not judged. Only if your car came (RPO UJ6) with air pressure sensors (you would have the decals around your wheels) would you need a tire gauge. If you car has a RPO DL5, you need the Roadside Assistance Brochure. Emergency key is not judged because it was reportedly delivers after the fact.
                  Ed Nieves
                  NCRS #51799
                  • Chris G.
                    • October 22, 2006
                    • 94
                    Thanks! When everything on order arrives, I should have a complete kit EXCEPT for the roadside assistance brochure, again, I show two possible options for the same brochure. Can anyone clarify if either are acceptable or provide a high resolution front and back scan of the correct brochure. Thanks for everyone help!!!!!
                    (I have the engine coolant supplement) on a side note - I am running green coolant in my car per many recommendations, will I lose points for not having dex-cool orange?
                    • Chris G.
                      • October 22, 2006
                      • 94
                      As a side note, was - after ten years - I was able to find the correct A/C delco Freedom 655 battery- yea me! And while I am here, does anyone have a 95 with the ink stamp still visible on the a/c dryer, mine is faded to non-readable. Any source on oe wheel weights and valve stems?
                      • Ed N.
                        • May 16, 2010
                        • 998
                        No will not lose points for having green coolant.
                        Ed Nieves
                        NCRS #51799
                        • Ed N.
                          • May 16, 2010
                          • 998
                          Does the battery work? Here is a picture of my bottle. Mine is a 95 with a November 94 Build dates. It always judges very well.
                          Ed Nieves
                          NCRS #51799
                          • Pat F.
                            • April 1, 1981
                            • 853
                            Guys, in my humble opinion re the Roadside Assistance Brochure. I do not believe it is applicable to at least the 1994-96 model.
                            The original owner after a period of time received a packet from GM and in it was a letter with roadside assistance information.
                            Also, this Roadside Brochure was replaced with a sticker that is on the driver side window.
                            In this class of C4's the emergency key was replaced by a Courtesy Key that was sent to the original owner after purchase and therefore not a judged item. This Courtesy Key was in a plastic sleeve and had the VIN number stamped on the sleeve.
                            Hope this helps
                            PAT, Central New Jersey and Florida Chapters
