I am replacing the soft top on a 67 including the weatherstrip. I have a questiion about the L shaped weather strips on the front header: The frame has four holes on the right side and three on the left. The picture in the assembly manual is not very clear but seems to show that these pieces should be fastened with one screw and three push pins.
Should I use three push pins and one screw on the right and three push pins on the left? The missing hole is where the screw would go.
Thank you,
Rand
Thank you,
Rand
