Power steering bleeding - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 384
    New p/s control valve + hoses, & system drained of fluid now --
    Should the bleeding procedure steps be conducted first, followed by valve balancing? Or, valve balancing first, then bleeding? I've seen it ordered both ways; maybe it doesn't matter.
    Thanks in advance
    Jeff
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Power steering bleeding
    No need to bleed. Just fill system, start engine, and turn wheels lock to lock a couple time. Stop engine, refill. and repeat. Then balance .
