C2 Radial Tires - NCRS Discussion Boards
C2 Radial Tires
  • Joseph T.
    • August 20, 2017
    • 5
    C2 Radial Tires
    Hello everyone. Sorry for starting a new thread but there are thousands of replies from 2004 and tires have changed so much since.
    I have a 1966 Stingray with Michelin 205/70/R15s with 5/8 W/W. The center on the treads are dry rotted and I need new tires. I have had them on there since at least 2003. All the main brand tire companies look like they stopped making these tires. I came across Cooper Trendsetter SE, Hankook Optimo and Tiger Paw Uniroyal. These are the only radial 5/8 W/W I have seen. What do you guys think???
    Any feed back would be greatly appreicated. Thank you.
  • Michael J.
    • January 27, 2009
    • 7178
    Re: C2 Radial Tires
    I have recently bought the Hankook Optimo, 205-75-15 and they are fine, I also bought a set of Goodyear Assurance All Season tires in the same size, and they are great. The 205X75X15s are more similar to the original tire dimensions than the 70 series.
    • Joseph T.
      • August 20, 2017
      • 5
      Re: C2 Radial Tires
      Thank you for the info.
      • Ronald L.
        • October 18, 2009
        • 3248
        Re: C2 Radial Tires
        Firestone Firehawk great black wall look
        BFG was to make another run of the Radial TAs you might check with the big box stores, they can get you into the correct size tire and they have the size converters on their web sites, the rack converter seemed most accurate and would even let you upsize the rims if you want to get fancy
        • Joseph T.
          • August 20, 2017
          • 5
          Re: C2 Radial Tires
          Thank you. I want to stick with the White Wall look. My Vett is White so the tires really pop.
          • John F.
            • March 23, 2008
            • 2424
            Re: C2 Radial Tires
            Goodyear black wall looks good as well on white!
            • Joseph T.
              • August 20, 2017
              • 5
              Re: C2 Radial Tires
              Yes they do. Nice ride.
              • Joseph T.
                • August 20, 2017
                • 5
                Re: C2 Radial Tires
                This is what the tires I have now look like on the Vett.
                • Brian K.
                  • September 19, 2007
                  • 174
                  Re: C2 Radial Tires
                  Hi Joe,
                  I too like the WW look. I put the Tiger Paws on a few years back and like them but.....the WW won't stay white. it urns brown. lacquer thinner helps but not 100%. To avoid, you have to go with Coker or something else where they make them to avoid that problem. I think Diamondback guarantees that won't happen. It's enough to make me consider replacing.
                  66 Coupe
                  66 Convertible
                  2022 2LT Coupe
                  67 Chevelle SS396
                  67 XLCH HD Sportster
                  • Frank E.
                    • May 31, 1986
                    • 189
                    Re: C2 Radial Tires
                    Originally posted by Brian Kane (47891)
                    Hi Joe,
                    I too put the tiger paws on mine a couple of years ago. Have the same problem with the white wall turning dark on the edges. To try and get them white results in a good workout.
                    Frank
                    1966 Milano Maroon Roadster
                    2004 CE Z06
                    • Gene M.
                      • April 1, 1985
                      • 4233
                      Re: C2 Radial Tires
                      BF Goodrich has that size too.
