A-arm Dust Cover Flap: Tucked or Untucked? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4603
    Did the factory tuck the bottom of the inner fender/A-arm dust cover under the A-arm, as shown below?
    Or was it left flapping around loose?
    I've seen it each way on judged cars.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Russ S.
    • April 30, 1982
    • 2163
    Re: A-arm Dust Cover Flap: Tucked or Untucked?
    They were tucked.
    • Ron G.
      • December 1, 1984
      • 865
      Like Russ said, tucked.
      "SOLID LIFTERS MATTER"
      • Michael J.
        • January 27, 2009
        • 7156
        Yes, that is how I have seen it most often. But it does beg the question, since it would seem visually that if it were left on top of the suspension components shown it would have been more effective to keep dust and water out of the engine compartment.
        • Ron G.
          • December 1, 1984
          • 865
          • Mark E.
            • April 1, 1993
            • 4603
            I also thought tucked, since if untucked the fan blows it around. Plus the cover has notches on each side for a clean bend.
            But when I pointed out an untucked cover at National, a master judge said they came either way. Inconsistent GM assembly?
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
              • 11678
              No. The judge was incorrect.
              • Alan D.
                • January 1, 2005
                • 2049
                For 64 see AIM section 11-13, sheet A2.00 for some guidance.
                • Paul O.
                  • August 31, 1990
                  • 1716
                  If it was untucked driving through a puddle the front tire would send a spray of water that would lift the flap and allow that water to enter the engine compartment.
                  • Ron G.
                    • December 1, 1984
                    • 865
                    In all my years of judging and I can probably speak for myself and Paul O. That many times that we have judged together and we have noticed that the owner was not aware that the dustcover flaps were supposed to be tucked in to control arm. We have actually gave him of her a verbal and suggested that he should tuck them in. I know myself and again most likely Paul we have never ever taken a deduction for untucked dust flaps. We just made the owner aware and left it up to him or her.
                    • Paul O.
                      • August 31, 1990
                      • 1716
                      Ron has that correct I would only inform the owner that the seal is typically tucked. But if I remember correctly that seal is under the Mechanical section.
                      • Gary J.
                        • April 1, 1980
                        • 1245
                        • David W.
                          • January 19, 2014
                          • 112
                          Just a heads up when judging a survivor. I would suggest that owners carefully untuck dust covers before judging commences in order to prevent inadvertent damage occurring to the original dust covers when they are untucked by judges to inspect ball joints. More times then not as the dust covers age they become brittle and very susceptible to tearing and or puncture when messed with. Been there done that. So if your original covers are in good shape the best solution would be to leave them untucked for judging.
                          • Leif A.
                            • August 31, 1997
                            • 3646
                            David,
                            Since when do judges touch or move anything on a car during judging? I've been asked to move/open things but have never had anything touched or moved by a judge in the three times my car has been judged. Don't think the judges are supposed to move anything. Am I missing something here??
                            Leif
                            • Jim S.
                              • March 13, 2013
                              • 360
                              Leif, You are correct. Judges are not to remove anything. Nor are "flaps" required to be untucked.
