62 Heater Control Valve - NCRS Discussion Boards
  • Ed P.
    • August 10, 2014
    • 89
    I sold one on ebay. The buyer says it is no good because he blew into both ends with his mouth and the air flowed thru. Ok when installed on the car i ASSUME the pressure from the water pump will cause the shut off valve to close? Its the water pressure that keeps the valve closed when in a closed position. Am i correct?
    ed
  • E B.
    • March 1, 1978
    • 126
    Re: 62 Heater Control Valve
    Ed, be sure they open and closed the activator, if still open then adjust the screw on the thermo tube sensor.
