95 LT1 Coupe - Ignition Key Stamp D or H - NCRS Discussion Boards
  • Chris G.
    • October 22, 2006
    • 94
    Hi, I just check both of my 95 ignition keys and do not see any stamp on the metal key side indicating either D or H keyway. Manual says it should be there. The are no close up photos in the manual. If anyone could help I would appreciate it.
  • David H.
    • June 30, 2001
    • 1544
    Re: 95 LT1 Coupe - Ignition Key Stamp D or H
    Chris,
    Believe only lock keyways have "D" or "H". Ignition keys have "VATS" pellet.
    Dave
    • Chris G.
      • October 22, 2006
      • 94
      Thank You!
      • Chris G.
        • October 22, 2006
        • 94
        Any idea how to retrieve the original key code from a 1995. GM does not provide the code to cars prior to 2002 currently.
        • Ed H.
          • November 1, 1999
          • 626
          Chris,
          My 1990 C-4 has the" D" on the door, glove box key. The Ing key (w/pellet) has no stamping. However if you have the knock-out for your Ign. key
          there is a stamping on the knock-out that indicates a code for the pellet. Many times the dealer knocked it out My code for the pellet knock-out is 7310. Hope this helps.
          • Chris G.
            • October 22, 2006
            • 94
            Thanks! I do not have the original knock out
            • Jerome L.
              • May 31, 2006
              • 34
              I agree with Dave. My '95 LT1 coupe has the "H" stamped on the two lock keys and the ignition keys are not stamped but have the pellet.
              • Pat M.
                • April 1, 2006
                • 1579
                Ditto for my 96.
                • Pat M.
                  • April 1, 2006
                  • 1579
                  Originally posted by Dave Perry (19643)
                  I know I've seen "pellet keys" with a 2-digit number, not a letter. (In about the same position as the letter is on Pat M's round key pic above). The number represents the resistance value of the pellet. Do ya'allz born-with ignition keys have a number on them? Or was I looking at key-shop pellet keys?
                  Dave, my born-with "pellet keys" do not have numbers on them as you describe.
                  • David H.
                    • June 30, 2001
                    • 1544
                    Dave,
                    Son’s 1996 does not have 2-digit number on pellet key.
                    Dave
