Judging A Quartz Clock - NCRS Discussion Boards
  • Rick R.
    • February 10, 2015
    • 142
    Regarding judging an operating clock that has a quartz movement installed, my understanding is that it would result in a 25 point (total "line item" deduction) under operations, and then a total deduction ( 10 points, 5 originality and also all 5 condition points) under interior judging. Is this correct?
    Thanks.
  • Gary J.
    • April 1, 1980
    • 1244
    Re: Judging A Quartz Clock
    Also a FAIL if you PV if you decide you want to go that route.
    • Frank D.
      • December 27, 2007
      • 2703
      Thanks.
      The ops check is what will kill you...not having that little rewind 'snap' every few minutes and the ticking effect. I don't know why you would lose interior points if the look is still factory...
      "The Clock Works" will put an OEM Borg mechanical movement in your clock for about $150. They did my 63 and it passed regional ops/interior with no deducts... I put a hidden 12V relay on the power line so I could stop the clock with a key fob remote for a longer life. I run the clock for car shows and judging only; per Clock Works recommendation. It'll outlast me.
        • 11659
        Thanks.
        Interior judging is appearance only. In addition, your battery switch is likely off during Interior judging, so no one can tell. As a result, there should not be a deduction. The only deduction would be from the Operations standpoint.
        • Gene M.
          • April 1, 1985
          • 4232
          No need to spend big money on an original movement clock. Any GM product in that time period uses the same Borg clock. Salvage yard generally just about give them away. Nobody today has a use for them outside us sick Corvette guys. Simple air cleaning and points clean up gets them ticking for another life. Maybe your Corvette’s own original clock just needs the same attention. Mine are all still working as they did when new. I do disconnect the battery when parked and I’m sure it saves the clock’s life.
          Judges should deduct for all aspects of an original clock movement that quartz lacks for operations. Yes full loss for quartz. Keep in mind a quartz clock is not in the flavor of restoration. No different than having a BBC in a 62 vette. Nice but not correct.......
            • 6948
            Gene, when judging a clock on operations is there a full point deduct?? the reason I ask is the reset function is also part of operations.
            • Gene M.
              • April 1, 1985
              • 4232
              If you look for all the attributes of an original clock; the tick sound, the approximately 90 second reset sound of the points, the hand movement, and the continual run for approximately 90 seconds after reset with battery disconnected. These are all attributes of the original a quartz will not demonstrate. Battery needs to be connected for operations and at completion disconnected. That is when the quarts will stop dead where as the Borg unit will continue to run for about the 90 seconds mentioned.
              A knowledageable judge will look for these attributes (and now you all will) to determine correct Borg vs quartz. It will make decision if not observed to make total deduction for quartz and be without question when reviewed with the owner.
              As for the reset knob, that should be demonstrated by the owner. Some quartz do not require the knob to be pulled out to move hands. Which is a failure. Maybe that is what you are referring to by reset function.
                • 6948
                Gene, I was thinking the tick- tock was 12.5 ,and the reset was 12.5, as some component's have multiple functions?
                • Rick R.
                  • February 10, 2015
                  • 142
                  I was thinking that it might also be a loss of points on interior since the interior judge could also see the quartz second hand sweeping continuously. I wasn't clear if the battery would be disconnected when the interior is judged. I'd like to keep my quartz clock for "everyday" use. The movements are like $80 and I've installed several through the years including one in my Cuda just last week. As you know, it's easy to remove the glove box and swap clocks. With all of this in mind, can you recommend someone reputable that sells rebuilt clocks with correct movements out right? (not rebuilding my current clock) Thank you all for posting.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    Not sure if I saw what year car you have; if its a 63 you can almost forget about a spare clock unless you really wanna reach deep into your wallet. Rebuildable clock cores are going for $500 and up...
                    • Paul O.
                      • August 31, 1990
                      • 1716
                      Several years ago the National Judging Chairman and Team Leaders made a change on the deductions for a Quartz clock in operations. If you read the latest judging guides it should state in some form that a Quartz clock receives a full deduction.
                      • Rick R.
                        • February 10, 2015
                        • 142
                        Frank, sorry - I try to at least put the 67 icon on my posts. I just edited this one and did so. I've seen some supposedly rebuilt with correct internals clocks available out right in the $500-600 range, but have no background on which vendors are known to stand behind their work. Clocks are finicky......
                        • Harry S.
                          • July 31, 2002
                          • 5330
                          There are several 67 clocks on eBay in the $100 to $200 range. If the cosmetics on your clock are excellent have it rebuilt with original internals then get a core on eBay and insert the quartz to drive with. Try Joe Ray, he is an NCRS member, for a rebuild with original internals.
                          • Rick R.
                            • February 10, 2015
                            • 142
                            Back to my original post/question.....So my reading of the ops section was correct, and a "full deduction" on a "line item" in ops = 25 points, correct????? Again, will the interior judge see the quartz clock second hand sweeping and also make an an "appearance" deduction, or will the battery already be disconnected? Thanks for posting.
                            • Rick R.
                              • February 10, 2015
                              • 142
                              Thanks Harry. My current clock looks excellent, and has an operating quartz movement installed. I want to hang on to it, and because I am impatient, I want to buy an already restored clock with original internals.
