1971 Corvette 454 Air Conditioning Compressor Rebuild? - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi All,
    In the process of putting back together an original 71 454. The car in question has an entirely original AC system that was removed from the car about 15 years ago. Before I go through the effort to restore all the parts correctly and re-install in the car, I am wondering if there is a reputable vendor who could check/ rebuild the compressor and associated parts. The last thing I want is to re-install everything only to find out I have major issues and then need to remove / clean and re-restore what was done. Obviously I would like to restore/ rebuild as many of the original parts as possible.
    Those who have restored cars with AC what process did you use? Any good vendors to recommend? Changing to Vintage AC is not an option.
    Best,
    Dave
  • Jeff P.
    • 799
    Re: 1971 Corvette 454 Air Conditioning Compressor Rebuild?
    David , Dom Tallarita is your man for compressor rebuilt. I got mine back a month ago. Work of art. dtallarita1@aol.com. Good luck.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • Larry M.
      • January 1, 1992
      • 2695
      Agree with Jeff. DOM is the best there is for the A6 compressor.
      What other parts do you want/need to be rebuilt?? POA and drier are two that can be rebuilt. Do you need these?? Others??
      Let me know.
      Larry
      • David S.
        • August 9, 2009
        • 595
        Thanks Jeff and Larry.
        I will reach out to Dom.
        I would like all parts or as many as possible to be checked and tested before install.
        Best,
        Dave
        • Larry M.
          • January 1, 1992
          • 2695
          Best,
          Dave
          Dave:
          Which ones????????? Dom doeA6 compressor work, but I do not think he will do any other rebuild/restoration, although you can ask him.
          There are places that do some of the other work........but you need to tell me what other things you want rebuilt so I (or others) can advise.
          Larry
          • David S.
            • August 9, 2009
            • 595
            Originally posted by Larry Mulder (20401)
            Dave:
            Larry
            Hi Larry,
            Likely want to test the drier, evaporator, condenser and valve. But also open to suggestions as to what is really needed in terms of testing and rebuilds before the system goes back together.
            Spoke with Dom earlier and he will likely do the compressor. Thanks for the referral!
            Best,
            Dave
              • 11644
              Did you read this thread too?
              https://www.forums.ncrs.org/showthre...AC-Restoration
              • Larry M.
                • January 1, 1992
                • 2695
                Hi Larry,
                Best,
                Dave
                Have your drier rebuilt by Classic Auto Air if it is an original. You can also buy a new one from DELCO that is almost the same as the one you have. Part # 15-1240. Also PaceCarJeff sells rebuilt driers on Ebay. Do not reuse the old one.
                You can and should pressure test the evaporator and condenser at home using shop air. Make some adapters to hook-up a pressure hose. Test condenser at 150 psig and evaporator at 75 psig. Immerse in water and check for bubbles at these pressures. Classic Auto Air can also do this for you for $$$ if you want...........but chance of damage in transit is possible.
                I can provide a test procedure for the TXV expansion valve or you can send to CAA for a checkout. Again, I would test at home.
                Larry
                • David S.
                  • August 9, 2009
                  • 595
                  Thanks Patrick. I did not see that, but will follow the thread and appreciate the referrals.
                  Best,
                  Dave
                  • David S.
                    • August 9, 2009
                    • 595
                    Larry
                    Thanks Larry.
