5/8 heater hose with GM markings and no ribs? - NCRS Discussion Boards
  • John M.
    • April 18, 2017
    • 184
    The NCRS judging guide for 1966 indicates that the 5/8" heater hose should be a plain finish (no alligator skin or cross hatch pattern) with no ribs and have a G M script and a box that are 5/16 high and spaced every 1 3/4 inches. Does such a hose exist and if so from which vendor or vendors. This info is from page 132 of the fifth edition of the technical information manual and judging guide. Thanks for any comments or advice on this matter.
    • 6948
    Re: 5/8 heater hose with GM markings and no ribs?
    John, in the similar threads below there is a very good post from Mike Hanson, Who use to be a factory worker. Good reading. also note that todays repro hoses there maybe a few makers but nothing is 100 % correct. the size of font and colors vary,
    • Donald A.
      • March 1, 1987
      • 243
      I had the same question and on searching through the usual vendors found most carry the ribbed hoses (both sizes). However I found that Corvette Central lists there 63-67 heater hose set as 5/8" non-ribbed with GM Logo and 3/4" ribbed with no GM Logo. This is as close as I could find to what the JG refers to so I ordered a set but has not arrived yet. Hence I cannot comment on the GM Script or Box size. I'll update this thread when my order arrives.
      • David H.
        • June 30, 2001
        • 1544
        Post? Don’t find a Mike Hanson in member list, in archives, etc. Do you have link to thread?
        thanks
        Dave
          • 6948
          David, scroll to bottom of this page and click on heater hose markings or not
          • Perry M.
            • January 1, 1977
            • 325
            My ' 63 still has the original hoses. They are non ribbed but have what you guys describe as alligator skin. So do my upper and lower radiator hoses and PVC hose.
              • 6948
              Perry it would be nice to a few pic.s ?
              • Gene M.
                • April 1, 1985
                • 4232
                This is exactly the points I attempted to share in my post of common error of restored cars. When persons start saying that’s too picky it destroys the intent of sharing information. My thought if it’s too hot in the kitchen get the hell out.
                John, thanks for sharing a source of CORRECT HOSES INFORMATION can be verified.
                It is too bad other one’s need to shoot down information that is shared with others on this site. Too many times followers of given restorers interperted practices have become accepted as “correct” when in actually it is NOT.
                Many of these shared points are small but in the spirit it is to make restorations closer to being correct as GM made these cars. It is not being picky it is just being closer to being totally correct.
                • John M.
                  • April 18, 2017
                  • 184
                  The next thing that comes to mind would be the judging guidelines for all mid years pertaining to heater hoses. Do the guidelines call for the same non ribbed but scripted hoses in 5/8 for each year of the c2 production? In particular what does the newest version (67?) have to say on this subject. I hope others with various mid year interests weigh in on this and that some type of accepted standard can at least in general be presented. I am guessing that many of us only have the JG for our particular year? Images would also be of interest as well as sources of available products that have been accepted as correct.
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    I here it is intended to follow along with each year manual to have the same content and wording to make it easier to flow from one to another. These things don’t happen over night. They are being worked. It may be the next iteration comes closer to this goal.
                    • John M.
                      • April 18, 2017
                      • 184
                      Will get a set of reproduction hoses from Corvette Central (SKU 452137). As posted this seems to be the most correct available product. Thanks for the advice and comments.
                      • Mark E.
                        • April 1, 1993
                        • 4597
                        The hoses on your car are 55 years old? Do you worry about hose failure causing sudden coolant loss and overheating? Or is your '63 strictly show and not driven?
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Michael J.
                          • January 27, 2009
                          • 7141
                          I have looked back over judging results of my 3 '64s over the last 3 years, chapter, regionals, and nationals, and since the '63-'64 TIM&JG states the hoses were "generally" not ribbed, the ribbed reproductions have not seen any deductions except at one national, where a 1 point deduction was made as "NTFP" finish in CDCIF matrix.
                          • Donald A.
                            • March 1, 1987
                            • 243
                            Hello John - my order from Corvette Central arrived so here are photos of the new hoses on my car.
                            • Perry M.
                              • January 1, 1977
                              • 325
                              I drive my car, although not far, and I do worry about the hoses. I inspect them religiously. The car has 43,000 miles on it which isn't a lot but you are correct, they are old. I know I will have to change them out someday.
