1968 327/300hp steel valve covers ? - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 803
    Are the 68 300hp valve covers different than the 69 to82 steel valve covers ? I know that 68 327 have the oil fill tube in the intake were the 69-82 are in the valve cover. Also were clips on the side for the temp sender wire?
    Thanks Bob
    • 43288
    Re: 1968 327/300hp steel valve covers ?
    Thanks Bob
    Bob------
    The right side valve cover was the same for 1968 and 1969. This valve cover had one clip on the rear, upper as mounted on the engine.
    I believe that the left side cover for 1968 was the same as the right side cover. Of course, the 1969 left side cover had the oil filler.
    • Bob W.
      • December 1, 1977
      • 803
      Joe Thank you for the reply. I though both sides only had one hole but wasn't 100% sure.
      Bob
